Discuss Boiler cycling when system up to temperature in the Central Heating Forum area at PlumbersForums.net
Hello,
can anyone explain what causes a Honeywell Ultracom 24hxi that works as expected when the system is cold, but when the system gets up to temperature the boiler starts to constantly cycle and fire quickly every 30 seconds or so.
- When the system is cold the boiler will fire for a period of time, then there is a long pause as the hot water is flowing around the system.
Has some sensor broken or something, I’ve had a plumber service the boiler without finding an issue...
Reply to Boiler cycling when system up to temperature in the Central Heating Forum area at PlumbersForums.net
I have a Glowworm Ultimate 35C boiler. It shuts off at its max temp of 60C when heating radiators and the pump carries on running pumping heat...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
1K
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate)...
Renato
R
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
