Discuss Blocked 10mm Speedfit Pipe to Towel Rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a blocked 10mm pipe to a Towel Rad. I have both ends disconnected (distribution manifold and Rad) but cant get any flow through it. I have tried mains hose on to one end, but it seems to hold firm.
Its never works since I've been in the house (18 months) and the property is aprox 15 years old. There has been historic magnetite in the systems, but I have drained/filled it a couple of times when I moved in, I have been operating magnetic filters and used a course of X800 and have Inhibitors in normally.
Its not the only rad with a flow problem, but I'm addressing them one by one by flushing just the One Rad circuit at a time from the distribution manifolds. See picture.
Ant thoughts other than replace the pipe or replumb the house ;-) ?
Many thanks
Adapt a foot pump or compressed to fit it. 8mm is a snug fit, so you'd have to put 10mm to 15mm adapter on and then a 15mm to 8mm. And then pump away.
as above and watch your pressure tho
the only other way you could try is putting some cleaner do there and see if that weakens it
I've always found these with near boiling water is good for dislodging most sludge. Just be careful of fittings blowing off. (its not fun when they do that)
What is the name of that device. I'd like to try that
Thx
Also adding fairy liquid and leaving it sit pressurised for a while seems to help.
Ok finally received my Pressure Tester courtesy of Amazon. :vanish:
i have it connected to the now disconnected 10mm feed from the 22mm 4 Port distribution manifold. The pipe runs use the floor and downstairs through the bathroom wall to the offending Towel Rad. I have also disconnected the check valve from the Rad so I have an open 10mm copper pipe with 15mm reducer.
When I pump the pressure tester I have had a small amount of water seep from the open 10mm pipe at the Rad, but it's losing pressure. I've taken it up to 15 bar, but no more for fear of blowing the plastic to copper joint behind the tilled wall. It very very slowly loses pressure but has not pushed the blockage out.
Any suggestions on the best way to deal with this ?
Many thanks....
Try pressurising from the other direction- towel rail end
Reply to Blocked 10mm Speedfit Pipe to Towel Rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
