Discuss Black Oxide, best way of getting it off a light carpet. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bostonlincs
Anyone have any tips, I cover up all the time but on occasions you get a dopey customer shuffling through your work.
Dab with blue kitchen towel, and then handful of warfega like hand wipes always works for me, just change the wipes regular away.
Elbow grease, prayers and I've used whatever i can find under the custards sink!! LOL Try not to spread it to far though! On the occasions it has happened I've soaked up what I could then used soap powder an warm water!
I use a sponge with fairy liquid, works every time but just keep dabbing lightly
how about when your blow lamp falls over just after you have used it and the tip lands on the carpet and burns it.... nope never happended to me!!! why do you ask??? LOL
Wire brush or reposition an ornament, newspaper!! :rofl:
luckily it was a flat above some shops one of which was a carpet shop. paid the bloke a tenner to repair with a piece from inside the wardrobe!!!! good as new!!!
Best way to get rid of a black stain in the carpet is to suck it with a wet vac (if you have one) then dab it with a dry towel. Then use 1001 stain remover.
Trouble is, this is so effective, it can leave a clean patch, when all around it is darkened!!
If you don't have a wet vac, just dab with kitchen towel. Then use the 1001 carpet cleaner. The point is to remove the spilt liquid before you clean, otherwise you just rub it in and spread it.
lucky you eh, in future it might be a good idea to get a professional in to clean it will score you brownie points with customer also if they ever spotted it on the carpet
out of interest how long have they bin carpeting lights???????????????
Stuff by JML is amazing for any stains. It's made with concentrated banana oil!
Some of these comments show why you guys have a poor reputation. The customer is the customer and they had a right to NOT have their home damaged! Someone has just ruined my bedroom carpet with radiator leakage and said nothing just left and sent me a bill as if it doesn't matter. I'm really upset and can't use the room until it's sorted. Thanks a lot!
Sometimes it's the really little things in life that drive us crazy. Like unregistered posters digging up a 4 year old thread..
Reply to Black Oxide, best way of getting it off a light carpet. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
