Discuss Biasi Garda m90f 24s flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi need to replace a flue on a biasi M90f 24s boiler. Does anyone know which flue fits?
Hi
It’s around 12 years old and it’s non condensing. The boiler has been capped because it looks like it’s got signs of spillage. The flue that is fitted is part number - 10999.0148.1 but it doesn’t look right. It looks like it’s for newer biasi boilers.
Thanks for your help
Who capped it ?
The guys capped it due to seeing daylight through the combustion chamber (he thinks it’s the wrong flue) is this correct? Is it normal to see daylight
Not normal to see daylight and cannot comment as if it is the wrong flue then at 12 years old you probably will not get the original. Unless it is the correct flue but fitted badly, in which case you can get the flue so fit a new one.
Reply to Biasi Garda m90f 24s flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, does anyone know why the water only fills 1/3 of the way please?
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Does anyone know a good, not super expensive, leak detection company in the London area?
