Discuss Biasi Boiler Low Pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RSM
Hi All,
Hope you can help as we have just moved into a new house that has a Biasi boiler in and is low on pressure. My knowledge is very low but I must be missing something obvious as I cannot work out how to fill the boiler? Pictures attached.
Silver flexi pipe first pipe with the valve on it
Your looking to get on the boiler pressure guage about 1-1.5 bar cold
Open the valve slowly
Thank you for the fast reply. Excuse my ignorance but I presume you mean the one further to the back with the screw on the front? If so how far should I turn the screw as I've tried this with no luck and didn't want to unscrew too far
No the one on the left the front one
The one you unscrewed was the port for the double check valve
Shouldn`t you close the filling loop afterwards?
Reply to Biasi Boiler Low Pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
