Discuss Best quality manifold and valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace two 17 year old 9 port underfloor manifolds and valves, can anyone recommend the best quality make ? Not too concerned about the price, I want good quality-Thanks, Nick
Have a look at imi hydronic
You will need to identify th make and type of pipe. As your new manifold wil need connections for that.
Lots of types.
Mclp, in 16 and 20 mm
Pex, in 15, 16 and 20mm
Hep20 in 15mm
Speedfit in 10 and 15mm
Polyplumb. In 15mm
Hopefully, it’s not contraflow, looks like red hose pipe. As you won’t get anything.
Lots of others I haven’t mentioned, but you will need to confirm, to get the matching connections
Post a pic of the setup and we should be able to identify
Reply to Best quality manifold and valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
