Discuss best boiler to replace ideal icos 15 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
phil hair
sorry to ask the same old questions again. Im due to replace an icos 15 he and im looking for your valued opinion.
I fit a lot of logic plus combi's , but the heat only requires a wire to the pump from boiler (for the pump over run)
I think i read somewhere that this is not required anymore, does anybody know if this is true?
Otherwise, what would you put in? It is for a landlord, so price is always an option.
thanks.............
thanks..
no pump overrun on logic heat anymore
Reply to best boiler to replace ideal icos 15 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got fd code on Ideal Logic Heat 15. Had two plumbers out and no joy. It’s had a new water flow sensor, flush with sentinel x800 and refurbished...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
I have a ideal logic 30 boiler ,the thermostat receiver looks to have died ( no lights on wired receiver ) I believe this need# replacing but in...
