L
learnplum
Hi, do most use a hand held device, or a spring, if you are a samson, or a free standing device, like the hilmor one?
Thanks.:tounge_smile:
Discuss Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If they're your girlfriends grandads benders they woulda been for 3/4 not 22mm I'd say
I would say a hand held device, in the year 2015, is backward?
Too much effort? Too pull a simple bend?
Hi simon why should I go too the gym, too bend copper pipe in 2015?
It is a struggle, too bend 22mm copper pipe on a basic bender?
Not floor mounted?:tounge_smile:
I was assisting on a boiler install once and we had to core through 2 3/4 inch iron rods that went through the external walls of a multistory building.. took 2 of us about 5 hours with constant drilling.. a light sabre would have been AMAZING!!!Cant understand how using a hand bender is hard work. Like i said, if you think that is hard work then maybe your username should be learndeskjockey rather than learnplumb.
Mind you I wouldnt mind a light saber for coring through walls.
Dosnt everyone else bolt a vice to the kitchen worktop that makes bending much easier!
Reply to Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
