Currently reading:
BBU/Fire Register Plate
Discuss BBU/Fire Register Plate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bewsh
Alright guys? Went to a bbu and fire service, chimney not sealed around liner, all other tests ok, advised the customer of issue and he wants the job done. I've never really fitted one before though, and there's not much room to work, I've ordered a couple sheets of ellis board to fix in the chimney. Obviously I'll need to take the flue hood off to get a bit of extra room, but even then it might be a bit of a struggle to get a drill in to get fixing. Any suggestions of getting it fitted without removing the bbu?
Also, would you class it as ar or ncs? The unsafe sits says ncs if its not practical to seal around the liner, but doesn't really define what practical is, it could be perceived differently by each engineer.
Don't need register plate for BBU.
Usual method to seal is block it off with rockwool/ fibreglass insulation.
A Quick run up to customers loft can usually supply sufficient insulation
for the job.
It's quite a wide chimney breast though, so don't know if rock wool would fill it without falling down
Start packing it and use an off cut of copper to push it further up usually does the trick
Reply to BBU/Fire Register Plate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
