Discuss Baxi Solo PFL - sooting up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tdslds
I have had quite a few problems with this boiler every since we moved to our house 8 years ago (the boiler is 9 years old)
Anyway, everything I have managed to resolve apart from one problem, the pilot light burns yellow at the tip after the main gas is alight for about 5 minutes. This would not be an issue but it causes that section of the heat exchanger to soot up. I have checked the gas rate and burner pressure plus I have replaced the gas valve (new) and fan assembly (re-conditioned) Also, two pilot injectors have been installed and the problem came back within 6-8 months. Think I have covered everything. Also, I have checked the flue pathway as it is travels vertically through the loft to a ridge tile (about two metres) I believe Baxi have an inherent problem with their injector.
Any ideas??
Mike
please have a look at the message bar at top of page in regard to question about gas.
Agreed.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Baxi Solo PFL - sooting up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, came across this forum this looking for information on my sooting up kitchen type indoor Enviromax. I'm a retired electronics/maintenance engineer, (fwiw can answer questions on popular smart home thermostat systems), but I've installed many solid fuel boilers in the last 40 years for...
2K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by the survey. I have had loads of plumbers over, and have always carefully checked their reviews/tried to vet them as much as possible. However, I've had...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know also not to bumble around blindly beyond that. We moved house last week and with the glorious hot weather we weren't bothered about the heating, more...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hi Everyone This is my first post here and I hope to hear from some of the experienced plumbers or anyone else in general that has had an issue with plumbing. In October 2018 a plumber came to install full central heating and a unventes cylinder which was zoned to two floors (Basement and...
2K
