Discuss Baxi solo 2 70 pf problem in the Gas Engineers Forum area at PlumbersForums.net
stings27
Evening all.
Have encountered a problem with neighbours boiler and wondering if one of you out there could help me.
When the programmer is turned on , everything seems in order. ‘Boiler on’ lights up, ‘fan on’ lights up, ‘pilot on’ lights up then burner on.
After around 5 minutes, the boiler cuts out.
When the programmer is then turned off, the ‘pilot on’ light is faintly illuminated for about half hour. This then goes off, programmer then switched back on and the cycle repeats.
Thanks in advance for any replies. 👍
Y plan ?
See what voltage your getting when off bet it’s around 50-70v
Normally would overheat faster than 5 mins could be getting weak
Reply to Baxi solo 2 70 pf problem in the Gas Engineers Forum area at PlumbersForums.net
