Discuss Baxi Luna HT 380 - how to display/set flow rate? in the Central Heating Forum area at PlumbersForums.net
The User Guide etc states an available temperature range of 25-80c. Various instructions found online instruct to turn it fully clockwise to display maximum 80c, then back it off and stop at desired flow rate, ie 55c. However, turning the dial fully clockwise (hottest) displays maximum 30c, and counter-clockwise (coolest) displays minimum 10c. The unit is functioning properly otherwise. Any directions here will be appreciated.
Thanks in advance.
Are you asking for flow rate or water temperature?
If you're trying to adjust the temperature and the maximum you can get is 30C, then something is wrong with the parameter settings on the PCB.
Best call Baxi to resolve the issue.
They should be able to talk you through it step by step
I think I mis-described; When the boiler comes on while it's cold outside, the displayed temp goes a bit over 60 (celsius) which seems correct for the dial at the first dot from the left. I'm looking for how to select the water temperature by turning the dial and stopping at the appropriate temperature. The highest and lowest displayed numbers are 30 and 10.
Thanks.
Reply to Baxi Luna HT 380 - how to display/set flow rate? in the Central Heating Forum area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
