Discuss Baxi inovia 30c no hot water in the Gas Engineers Forum area at PlumbersForums.net
Matt0167
Hi guys any of you lot familiar with these ,
Not firing for hot water at all doesn't even try, had the call brought a hot water flow sensor as it was only pennies saved going back to merchants , no joy ... heating works fine.
Can some one explain to me how the sensor works ( on a blue tab right hand side inlet manifold) I removed what they called a flow switch this is just a white flow regulator as far as I can see with a filter nothing in there and all clean
Any help or info would be appreciated
Matt
[automerge]1574283320[/automerge]
Not firing for hot water at all doesn't even try, had the call brought a hot water flow sensor as it was only pennies saved going back to merchants , no joy . heating works fine.
Matt
I’m guessing it goes off rotational part 13 so if no fire on when you replaced 14 replace 13 should be good then
Thanks shaun that's my plan tomorrow ,
Just interested to know how 13 works as the description says magnetic flow switch filter
I didn't see any magnetic piece inside that moves or any switching moving part ?? Just looked like a filter and had a flow regulator inside
Same principle as the logic flow sensor
Spinning magnet and the sensor externally
Just a quick update to let you know I stripped down item 13 , (magnetic flow switch filter) inside there is a flow restrictor that doubles up as switch
Pulled it out and blew down it as if there was water flowing through it , nothing happened give it a quick tap and a clean and hey presto there is section inside that spins, All working fine.
Hope this helps someone else
Reply to Baxi inovia 30c no hot water in the Gas Engineers Forum area at PlumbersForums.net
