Discuss baxi duotec in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mickie
Hi, another baxi question, fitted an A rated grundfos pump, boiler was working fine but now and again after fitting this pump i get E168, tried on setting 1 and 2, still randomly get this error.. once i reset its back to normal... Dont they like the lower Wattage ?
The other change is balancing the system and as the 9 rads that are in this house are small, they're turned down a lot, currently on 15c difference at the boiler return..
Why are you fitting a pump to a duotec? They already have a pump inside
E168 is normally a pcb issue,have you fitted a different pump?
Yeah ive fitted a different pump, ups2, to save energy and reduce the pump speed as it was too loud imo, this is for my house, normally id not care..
the old pump runs on max speed, so i swapped the pump head for an ups2 so lower the speed and save on energy..
That will be your problem,feedback from the pump is killing your pcb ,it will eventually totally fail
That's a tad annoying, the old pump running flat out was getting pretty annoying..
What about fitting an older style pump i can reduce the speed on and taking the ups2 out ?
cant you stick in an old 3 speed non erp pump? the ones with a lever on the side
Reply to baxi duotec in the Plumbing Jobs | The Job-board area at PlumbersForums.net
