Discuss Baxi Combi Instant 105 HE hot water issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
markofled
I have a problem with a Baxi Combi Instant 105 HE. Initially when i turned the hot tap on the boiler didn't do anything but when i pushed the micro-switch on the DHW pressure differential valve the boiler fired up and the water started coming out hot. So i replaced the Differential valve. Now when i turn the hot tap on its seem to either go around the preheat section of the boiler or down the central heating never solely around the plate heat exchanger. Im leaning towards it being a fault with the diverter valve? When i changed the differential valve i noticed that there was a pin coming from the part behind it what does this do? I was wondering if this was the point when the water was being sent around the pre heat instead of the heat exchanger?
Any help would be very welcome!
Sounds like a job for your GSR engineer im afraid,
I am GSR just not the most experienced when it comes to boiler breakdowns. Just hoping someone with a bit more experience might be able to help? Im struggling to pin point one part as the problem.
As you are a GSR engineer then, either clean or replace the control assy on the front of the divertor and check the heat exchanger too for scale or blockages.
Pm croppie or gas man with your gas safe number and they will tell you how to gain access to Gsr only forum. Loads of advice in there
Been told I can't do that yet. So stuck here for the time being.
Can anyone tell me does the water get diverted to the pre heat circuit at the divertor valve or at the differential valve assembly ( back half)? I was think the heat exchanger would be my next step, they had said hot water temp had been fluctuating prior to lossing hot water altogether.
Reply to Baxi Combi Instant 105 HE hot water issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
