W
Will Silver
I have just started to get a problem with the fault as the title, this is the flashing light by the triangle/ 60 degree section.
This has happened twice now in the last two days.
Neither the central heating or the DHW works for a period of time say an hour then the light will stop flashing and things are back to normal.
I am just wondering if there is a component thats on its last legs, and would look to change that rather than it not coming on at all.
I have watched the operation of the microswitch and the pin for both DHW and CHW and both appear to be working fine, the pump operates then the light starts flashing.
The only thing I can vaguely recall reading somewhere was to do with the automatic air vent on top of the pump, but I am sure somebody will point me in the right direction.
The pressure in the system is fine and I changed the complete DHW pressure differential valve in November of last year.
