Discuss Baxi 105 HE cool radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all
1st post so be gentle
when i moved into the property we had 5 single and 1 double radiators all providing loads of heat
1 - Kitchen
1 - Living Room
1 - Hall
1 - Bathroom
1 - Bed 1
1 - Bed 2
1 - Study
1 - Double Dining Room
Since then ive exchanged some of the singles for doubles
1 - Living Room
1 - Bed 1
1 - Bed 2
The rest are as original
when installing the last rad (Bed 2) and recharging system ive noticed that the radiators arent as hot as they were, also the return pipe is cool (all lockshields and TRV are fully open)
Ive replaced the Grudfos pump for a 3 speed one and set it on speed 3 and put sentinel x800 through the system.
ive also noticed that when you open the kitchen tap 1/4 turn steam comes off the water flow but if you fully open the tap it is noticeably cooler (the DHW Diaphragm has been changed two days ago)
ive ordered a CH diaphragm just in case its that and also a new PCB, its also worth noting that the boiler temp very quickly achieves 80 then pilot light extinguishes (no fault LED) and doesn't reignite until 30/40 is reached, any ideas?
Pointers about what mate? Working illegally on your boiler?
I don’t think you’ll find part of the problem is the boiler is your system water dirty?
If you have changed single rads for doubles that does not mean you will automatically get more heat out. Pipe size counts for a lot. I am not saying that's the answer but it could well be an influence.
The Water temp coming into your property will have an effect on the temperature of the hot water out of a Combination Boiler. There will or could also be differences due to flow rate.
My advice to you is to get a Heating Engineer to deal with your issues. It does sound like you have more than one or two but they may not necessarily be as a result of faulty components.
Throwing parts at something and using guess work will only cost money. It could work out a lot cheaper to pay an experienced Heating Engineer for a couple of hours to sort things out.
Reply to Baxi 105 HE cool radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have a customer with a modern anthracite vertical radiator and a modern TRV and lockshield. The radiator makes a loud metallic bang from...
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
