Discuss bathroom extractor fan in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ted808
Hi Guys
Can I wire in a bathroom extractor?. Cables are in solid ceiling. Can only access cord pull for light and light fitting- seems like there's L N E in the light fitting and L SL in the fitting - the fan has a timer I think I got the wrong one.
Cheers ted
  • :willy_nilly:
You need permanent live in addition to switched live for timer to work.
As above also depending on what zone it is in it might need to be 12v
I'm not sure but bathroom electrics used to be 'notifiable' and as such the person doing the work or certifying it needs to be suitable qualified and certified.
Just be aware that if it is notifiable, you DIY it and you have an electrical fire your insurance company could invalidate your insurance!!!!
Be very careful.
Hi Guys
Cheers ted
  • :willy_nilly:
You should have L Ls N E on your light fitting. Take a 3 core + e from there to isolator (check if required by manifacture) then from iso to fan.
If 230v fan is fitted above bath or shower then it must be above 2250mm or be 12v
No it is not notifiable work. A minor works cert is recommended.
Good luck
Hi Guys
Cheers ted
  • :willy_nilly:
Good luck
Good luck
Thanks I think I'll get a sparky as soon as you say switch live my brain goes bzzzzt!
Reply to bathroom extractor fan in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
I currently rent a flat but the bathroom does not have a window. Weirdly last year we had no issues but this year we have noticed mould spores on the ceiling and shower curtain. This has been removed by mould cleaner. We have an extractor fan but it’s small and only works for around four minutes...
Can anyone help with this please? I have had a bedroom and en suite installed in what was loft space above my garage. Unfortunately there is no way to run the ventilation ducting from the extractor fan into the main roof to access the ventilation tiles. Due to steels/roofing timbers, at most...
Hi all, We recently had a ground floor bathroom/wet room finished off, It's about 3.6m long by 2.7m wide, tiled from floor to ceiling and has no window in there due to a future extension that will take place on the other side of the rear wall. Unfortunately, i've Instantly noticed when...
5K
Our current heating system has a Potterton EP2002 controller and Potterton Prima 60F boiler. I have bought a Wiser multi-zone kit 2 plus a number of Wiser TRVs in order to have easier and more fine-grained control. Replacing the EP2002 with the Wiser hub simply involved swapping the wallplate...
2K
Hello all, I am hoping that you can give us some advice. We're in the UK, and have contracted a company to completely refit the first floor bathroom. The first fix was completed a few days ago. We haven't moved in yet. When we returned to the property just now, the kitchen ceiling had caved...
1K
