Discuss Bath without anti vac trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey I've got a bath to fit that happens to be on the end of a waste/ soil pipe run. The bath has come with a waste and trap all connected up. However the trap is not anti-vac, will this be a problem anything I can do to over come this?
Quite possibly, best to insert a mcalpine antivac tee/ socket which fits inline.
i wouldnt worry baths very seldom empty the trap as the shape means there is a lot of run of water which refills the trap even if the initial flow empties it if yoyur not having problems i'd leave it
http://m.NoLinkingToThis/p/floplast-air-admittance-valve-32-x-40-x-50mm/42968?filtered=true
Reply to Bath without anti vac trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
