darrenh
Hello all
I am replacing a bath and shower that are independantly fed - the bath runs from the hot water cistern / cold water tank in loft. The shower is the same but via a high pressure pump.
Here is my issue: the valve I have bought is one of those that has a single supply and you can divert the water to either the shower or bath.
This means that the bath would be fed by the high pressure pump (and it is pretty powerful).
Without the pump the bath fills pretty rapidly...
Does anyone see a problem with this i.e is it ok to fill the bath using the pump (in which case I can just cap the existing feeds for the bath)?
I fear when i run a bath it will be like niagra falls.
Darrenh
Darrenh
