Discuss Basin bottle trap corrosion in the General Off-Topic Chat area at PlumbersForums.net
N
Nea2023
The Basin bottle trap is in bad condition and begin to loose water due to corrosion (I believe it is lead). May I use pattex putty paste or collak as an emergency solution? How can I loosen the bottle trap nuts? They are so rusty and calcified I am afraid they may break if try to unscrew them. Thank you.
Use what you need to prevent it from leaking as it's only a trap, expect the worst once you attempt the disassembly i.e prepare to have to replace it all so it doesn't matter if you break the nuts. It sounds like they aren't reusable anyway.
Reply to Basin bottle trap corrosion in the General Off-Topic Chat area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
