Discuss Balanced flue gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
finchy01
Morning all, a new customer has approached me asking for a balanced flue fire as there current fireplace has had the chimney removed. The only problem is there is a garage the other side of the wall. I've installed a few like for like fires but never a Balenced for our fan flue one. Do you know of any fires that I can put 3m approx of horizontal flue with elbows? I would need to come through the wall into the garage then elbow a couple of times to come out of the front of the house at low level and then fit a terminal guard over the terminal. Does such a setup exist? If so any idea of manufacturers or suppliers? Many thanks.
I have never seen a balanced flue installed as you describe.
Can you not use a flueless Gas fire? it's the easiest option by the sound of it. It will require ventilation but no flue obviously.
I wouldn’t fit a flueless gas fire if you paid me a weeks wages. Rubbish idea.
Well Sir, it was only a suggestion and possible the only answer he may have.
I appreciate that you dislike the appliances but I do have to point out that they have been around ever since the memory of man are are very efficient. They are also safe if installed correctly.
Can I enquire as to whether you are suggesting that 'my' idea is "Rubbish", or the idea of a flueless Gas fire?
If it was my idea, then I can only respond by telling you that it was a suggestion and a very good one in my opinion.
If it is the 'flueless' Gas fire you dislike with a passion, should we therefore condemn all flueless appliances and refer to them as "Rubbish"? what about Gas ovens, Gas hobs etc.
I look forward to hearing from you with great eagerness lol.
:D:D:D:D
Thanks for the replies. It's as I expected but wanted to call on your wisdom before saying it's not possible (if it is it'll be specialist so most likely very expensive).
:D:D:D:D
Well that escalated quickly? :eek: Where in my post did I mention you? I said “I” the reason I do not like them is people never ever get them serviced annually which makes them dangerous.
Reply to Balanced flue gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys, My chimney failed the test so I need to install a flue liner for my Gazco Stockton gas fire. It was over a year ago when the engineer...
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my...
eco-heating options
E
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
