Discuss Back to wall waste help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, hopefully attached picture is clear. I don't have enough space to get down and across from my wc outlet to the waste tee on floor. The tee in floor is the push fit type with the rubber ring inside, so I'd need to pipe it as well, before getting a flexi in. Anyway, flexi just won't work. Too close. What I'm wondering is whether the following would work. If I cut the tee just after the push fit part of the joint, am I left with a standard 110mm that I could push my flexi into? Would that work? Any other suggestions? Cheers
Doesn't the toilet want to go back more or is it near final position??
Could you pull the tee out the floor push fit joint and use a piece of pipe with a socket on one end to raise the tee slightly higher
And then re do your basin waste
Unfortunately not. I've solvent welded the waste behind tiled wall, and the tiling actually comes down on top of tee. This was all deliberate so I didn't need to build a bulkhead. Now I'm finding out why a bulkhead makes life easier
How much roughly do you need to make up?
To meet what's there, I need to go left 80mm and drop about 50. Problem with the flexi is I can't get it to take the shape I need over such a short distance.
Interesting, who else here if in that situation (although I'd have used a jubilee pan con paul) would high strength silicone the pan connector in after fitting for peice of mind?
Ive seen a few which start to creep out over the years and can drop off if the toilet is plungered.
Plumber mait for me to allow for tiny amounts movement.
Seems a bit of a bodge but I guess time will tell.
ShaunCorbs idea sounded pretty good
Reply to Back to wall waste help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a...
Hey everyone, I have a Duravit vanity unit and was recommended to buy the Duravit space saving waste: 005076 But im unsure how this connects...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
