Discuss Back boiler still kettling after cleaning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I put some cleaning fluid through my system about 6 weeks ago and drained down at the weekend I ran the heating until the water was clear but after filling I still have kettling when only HW is running.
As far as I’m aware the HW is heated by gravity as I cannot see a valve only the pump.
Am I missing something when cleaning this type of system or have I not run the system enough? Should I have let the system settle then run the heating again to remove more dirt? Should I shut the valves on the other radiators then run the system to force everything out of that drain?
What other options do I have?
It wouldn’t be so bad but the pipes come under my bedroom floor and obviously the boilers in the living room so it’s hard to get away from the noise.
What boiler is it? If it is only a slight kettling you may get away with putting some silencer into the system.
If it’s an older boiler with heavy kettling there’s nothing much you will be able to do.
Try harvests suggestion just in case it can be quietened
I had similar with hot water on a older boiler partially blocked pipe work. sludge had settled in the bottom on the flow to the cylinder.
Thanks for your replies yes it’s an antique but it doesn’t cost anything to maintain in 12 years we have only had to replace thermocouples and a solenoid.
Has anyone ever used the over flow and a compression fitting and hose pipe to flush the other way? Is there any reason this could not be tried?
standard cleaning fluid is no good for getting rid of scale, it needs a proper de-scalar (Acid) in system have a look at Kemco product's
Yes not great way of doing it tbh
Reply to Back boiler still kettling after cleaning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
