Discuss Back boiler plumbing circuit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Japnut04
Plumbed this up last week an having a problem with it, the gravity flow from the stove works fine, its just when the pump for the stove kicks in the return from the rads seems to go up through the coil instead of back to the stove, put a gate valve on the return link which helped but still not right, its cooling the hot water in the cylinder every time the pump runs, cheers for any advice giving.
are both boilers feed from the same cistern in the loft to give the same head?
I only have the back boiler side fed from the f+e tank at the minute didnt get around to putting in a new pipe for the ch side of things
you should have used a injector tee on the stove you would have no problem
Cheers for that, i got an injector tee today must fit it a see how it works out.
Reply to Back boiler plumbing circuit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate...
I have been told that I can't have a mains pressure unvented hot water cylinder with a back boiler on a wood burning stove as the heat source is...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi, I have a stove pumping over into the f&e. The pump and thermostat both work and the system is free from sludge (very clear for an open vented...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
