Discuss ASHP Installation Qualifications in the USA area at PlumbersForums.net
I saw in the news the latest craze in the UK is heat pumps for hot water and heating. I wondered if a heat pump installer in the UK needs an F-Gas qualification to do this type of installation in a domestic/commercial environment and to sign it off.
Depends on what type marvo we’re moving away from the older f gas ones into all in one units with just a flow and return connections
So I guess the answer is non
Am I right in thinking if it's a split system with a precharged kit, you don't need F-gas qualification? Not sure where I got that idea from, but have an idea it's a 'thing'.
Depends what you mean by split system if you mean like the ac uses eg indoor unit and external then no you do need to be f gas as you need to check and pull a vacuum
There was something you didn't need for the spilt systems (and yes, I mean like the AC uses indoor unit and external). Can't remember what it is you don't need then. Oh well.
I have done a couple and I'm not f gas I did a dimplex unit and a Mittsabushi, companies we're offering a umbrella scheme at the time where they came out a commissioned after installation and offered guidence through the installation process this can lead to MCS once you have proved your competent but this was early doors when ASHP s came available . Kop
I believe you only need to have your G3 unvented cylinder qualification for standard mono heat pumps.
Mono heat pumps have a sealed refrigeration system and so no F gas work is required.
Hydro split ASHP's use water between the outdoor unit and indoor unit so no F gas required.
A refrigerent split does however require F-Gas qualification as refrigerent pipework is required between the outdoor unit and indoor unit, benefit is the outdoor unit can be sited much further away.
MCS (and umbrella schemes) are only required at present if you are claiming for the RHI, new build etc does not require MCS.
The majority of installs are mono systems using the likes of Daikin, Samsung, Mitsi etc and so would only require G3 unvented certificate. (Plus MCS if claiming RHI).
Very well explained Ant that's cleared that up .👍
Are these new type units all in one package? Do they need to be ducted to the outdoors?
There normally installed externally and the flow and return pipework has glycol in it due to our low temp winters and there normally piped to buffers / if system is designed correctly straight to the system
Reply to ASHP Installation Qualifications in the USA area at PlumbersForums.net
https://www.telegraph.co.uk/news/2023/05/12/the-heat-pump-farce-has-finally-been-exposed/?li_source=LI&li_medium=liftigniter-rhr I realise not...
2K
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in...
2K
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the...
L
Hi, I’m a uk resident with plenty of plumbing and heating qualifications. However I was wondering what kind of qualifications are required for...
3K
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
