Discuss Asbestos in warm air unit being removed?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RDS
Hi everyone, just looking for some advice for decom and removal of a Johnson & Starley J25-32 Modairflow that contains asbestos. Haven't had to take one out before and customer (and me!) is concerned about the asbestos in it. Is it possible to remove complete unit without disturbing anything? Those with experience what do you do in this situation??
If your both itchy best get a firm in to remove the ab and normally ab flue
I'm thinking the customer would rather have a specialist firm into remove, but might not be so keen when see how much it will cost!Have you removed one of these in the past for a central heating install and did you just get suited and masked up and took it out carefully??
Reply to Asbestos in warm air unit being removed?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
