Discuss Ariston microgenus 23 muffi leak issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jitenbulsara
Evening
I have a ariston microgenus 23 mffi which has a diverter leak by sensor and also below actuator motor and then also looks like slight trace of water behind pump housing but really had to see. I would be inclined to change the diverted as I don't want to return after repair. Has anyone tackled a leak behind the pump housing n did it need a new housing ?.
Any help would be great
Thanks in advance
Ive had the pump leak from the seal where the pump head joins the plastic hydroblock behind it.
It just needed a new seal and it was ok. Are you sure its not the auto air vent letting water out?
It's totally dry from the auto air vent. But I can see it seeping from the he sensor and also by the actuator motor
Reply to Ariston microgenus 23 muffi leak issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
