Discuss Ariston Euro Combi 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Backboiler
Does any of you have any experience working on the Ariston Euro Combi 30. I have a leaking diverter valve cartridge but there is no room above to remove it. The sealed chamber floor is is only about 30mm from the top of the actuator head which also cant be removed. Do you have to remove the right hand block from the boiler in order to change the cartridge?
Reply to Ariston Euro Combi 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
