Discuss are magnacleans essential? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
anyone know if not fitting a magnaclean on a combi conversion of an old system will invalidate warranty on boiler? also what other get out clauses do manufacturers use? ie not powerflushed etc.
any info appreciated ^^
the warranty will be void if you dont power-flush the system
That's not strictly true, only needs chemically flushed
But for magnetic filters, yes, fit them is much advised
old wives tale!
recently noticed boiler benchmark now ask if there is a system filter installed!
you willing to take the chance with boiler mis trying to find every loop hole to get out of warranty
you dont have to power flush to get the warranty cover old son, just flush and treat as required using chemicals if needed
its not worth not fitting one as the customer is paying for it and it stops the manaufacturers favourite get out of water quality
my issue is because the customer is paying and me not being a very good salesman, i hate having to talk them into having one fitted if they're trying save money, almost as much i hate not fitting them. Seems like everyone just wants bare bones
thats a new one by me as reading a few mi they state must be power-flushed even says on bench mark/there own brand
do let me know which manufacturers insist on a power flush, not seen one saying so yet in any MFIs
the new Worcester ones i think
more old wives tales, I think
i thought that not fitting them (on worcesters specifically) could be a reason used to invalidate warranty if the system isnt completely clean even after a flush. Am i completely wrong or just a bit wrong?
A bit wrong, they want you to use there branded filter to up the warranty.
know this may seem strange...but i and others were putting inhibitor in systems 35 years ago,when came into trade...i replace the boiler,the system is spotless....what is a magnetic cleaner going to do.....if no rubbish in system ..nothing to damage boiler..end of.....i replaced a neta heat last month..system like spring water.....i have replaced 10year old boilers that the pipework and rads need changing....think what you are trying to achieve before you dive on fitting gear for no reason.....
Reply to are magnacleans essential? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
