Discuss Anyone using ideal logic systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
RGII79
I have a problem with a 3 week old logig system 18 intermittant leak inside boiler casing checked blow off and not passing aav ok and all seals seem ok but pressure not above 1 bar and 3 calls since install saying leaking from rubber gromit elec cable bottom of boiler. unsure whether H EXCHANGER OR CONDENSE TRAP WERE ALL FINE WHEN I CHECKED OTHER TIMES
Did you check the rubber elbow on the condense trap? had one which was kinked before causing intermitant leak. If in doubt ring ideals out its under warranty so use it!
Yeah i checked and all seem ok its a weird one i ran the boiler today for nearly 2 hours watching everything and nothing even ran the blow off valve and aav no leaking .then received a call this evening saying water coming through gromits again below boiler
Im just thinking could it be condense getting into the air intake from a leaking seal on flue elbow have u ever come across this before
or may be a rubber seal which is only weaping when boiler cools down
called back today to logic boiler opened up and checked condense trap found particals of grass in
checked outside and rain water guttering from roof full to brim with grass and and is belly in lenght when raining it fillsand curtain of water falling acroos face of flue below and it was pulling it through air intake and exaust.
just about to call ideal tech when i found this thank god covered and isolated before she blows the pcb till she gets the gutters fixed
Reply to Anyone using ideal logic systems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
1K
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Most efficient way to heat water in tank using ideal logic boiler? Hi guys I have a water tank as pictured in my profile with an ideal logic...
Hi. I have an issue with my Ideal Logic+ System S24 boiler which I hope someone can help with. Below is as much detail as I can think of. The...
1K
Hello guys! I had an Ideal Combi Logic+ C24 fitted in August 2021 in my mid terraced house and I started noticing that it was losing pressure...
1K
