Discuss anyone used Geefix fittings to hang radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Paul and welcome,
Never seen them before but looking interesting to me. I cannot tell you really if they're good or not. My experience with spring toggles or hollow wall anchor are good. I cannot complain about those cavity fixings. I was just thinking if you really had so much space to fit the big plastic inside the cavity ? Sometimes you won't have that much space but It's worth trying the geefix if you ask me. I definitely will give it a go thanks for sharring.
I would say no from me plasterboard will only hold so much all your doing is spreading the load out to a bigger surface area and in theory this is great, but the base material needs to be able to take the load
Anything over 1m x 60cm is a no go for plasterboard unless your fixing directly to timbers behind
Thanks for the reply. I will let you know how I get on
Thanks for your thoughts. Will post how I get on. Ideally I would have liked timber instead of plasterboard but I think the Geefix will be my best option
Hi, I recently used these Gee fixings and would recommend them. They are holding very securely a towel radiator 1100mm X 600mm. Very neat and easy to use. However I would suggest only using them as a last resort as a stud is the best choice
Reply to anyone used Geefix fittings to hang radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
