Bit of advise/help required lads, here is the problem i have at home with the boiler.
I have a 35kw icos which used to feed my heating/hot water cylinder (valiant 300litre unvented solar twin coil), system controlled by honeywell s plan. 17 radiators the whole system has worked perfect for 5/6 years.
I have now altered the system, the icos now just just feeds the cylinder, cylinder stat is now not connected, cylinder temp is controlled by boiler stat only, pump is controlled with switched live from programmer, system is is sealed exp vessel is fitted.
I would expect the hot water heat recovery to be bloody quick with this set up (it was always good with the s plan setup), however it now takes ages (hours) for full recovery, pump is a new grundfos alpha 2, i have tried it on lowest and highest speeds, it runs all of the time when the programmer is on an on program.
The boiler stays off on stat for ages (always has switched live feed same as pump. The problem seems to be as if air is still in the system i.e. pipe only half full of water, you can kind of here it........the boiler and cylinder are only 3metres away from each other, honeywell auto air vents are fitted on flow and returns to both boiler and cylinder........these are working correctly and the system is fully vented and treated with x100.
Do you think i need some sort of micro bubble eliminator????, if so what make do you reckon as can't seem to find one on the spiro website.
Have you ever came across x100 frothing up it if a system is overdosed, there is no more 12m of 22mm pipe fitted to the flow and returns, and a full bottle of x100.
Heating is superb as i have installed a Remeha 18kw system boiler completey weather compensated.
Any ideas?????, BTW there are defiantly no partial blockages in cylinder or boiler heat exchanger, and the boiler stat is within correct tolerances, so deffo would appear to be a heat transfer issue.
