Discuss Am I being dumb or is this a thing? in the Central Heating Forum area at PlumbersForums.net
Yes common as the incoming water temp drops your rise won’t be as much eg in summer you will have hotter water than in winter
Yes it's a thing. Combi boilers are a compromise. You have hot water on demand, you don't use energy to heat and maintain a cylinder, and you save space, but the faster you run your hot water the less hot it will get.
Your penultimate paragraph shows you have understood the issue perfectly.
Thanks all…. So next question….
Is there a fix?
Something like a small pressurised cylinder that can sit in loft just before boiler? Perhaps with a small element that takes the chill off the water inside so the boiler doesn’t have to work so hard?
Of course there is a fix. There is absolutely no reason you can't have a cylinder of whatever kind you like (with or without electric backup) as well as a combi boiler. You could even run some hot taps off the 'combi feature' of the boiler and others off the cylinder. Or you can just restrict the maximum flow to the bath or shower.
In practice, you won't want a bath or shower above 40°C, so it may not be a massive problem so long as your hot water temperature stays at 50°C or above. It's worth noting many thermostatic mixers will always deliver water that is no warmer than 10°C less than whatever your hot water temperature may be, but you can find thermostatic mixers (Grohe makes one, for example) that will deliver water to within 2°C of the hot water temperature. So, with such a kind of mixer, you could still have a 38°C shower (the normal recommended maximum safe temperature) when the boiler is outputting hot water as low as 40°C.
I must say I have toyed with the idea this kind of setup in a personal capacity as I have a bath that is only used once a week or so but could easily live with a combi's hot water output the rest of the time.
Not sure if this helps, but I had a combi in my last house and it had a pump connected to a temperature controlled head (electronic), it seemed able to pull the water through at a decent temperature.
It heats the house fine and before this spell of cold weather the hot water was fine too it seems that the system struggles to heat up very cold incoming mains pressure water and push it through at a high temperature.
Is this a common thing?
Think on it: you have 28kW which should be plenty for heating a medium/large house. However when heating an incoming water supply you need a lot more: assuming heating from 10C to 43C 28kW will give you about 0.2 litres/sec. A domestic bath is normally assumed to be about 0.4 l/s so no chance of getting high flows and temps unless you have a stupidly large boiler! Suggest you look at an unvented cylinder.
All makes sense gents. Thanks for your help.
For the time being I’ve reduced the flow from the hot into the aqualisa system. Not by much but just enough so that when it calls for hot it allows the flow to be hot enough to shower under. It makes little difference to the actual power of the shower.
Longer term and invented cylinder is definitely the answer.
Reply to Am I being dumb or is this a thing? in the Central Heating Forum area at PlumbersForums.net
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
I recently had an eco tec plus 836 combi installed as part of an oil to gas conversion. One thing I can’t work out is why the bathroom sink hot...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
