Discuss alternate straight through CH return valve for combi in the Central Heating Forum area at PlumbersForums.net
I'm in a bit of a bind with a current CH install where I need to install a filter prior to a flush but no where to install
My issue is the return on the combi (ideal 35) runs directly behind the boiler then up through the ceiling so I have no clearance to even attempt to snake it out to fit a filter also the CH is all concealed pipes with 10mm Hep2O feeding the rads so I couldn't even place it elsewhere on the system like the last rad.
My question is does anyone know of a straight through return valve for the combi to re-orientate the return pipe to vertical as this should give me just enough clearance to create a loop for a filter and then back onto the recessed return to the rest of the system.
I have called Ideal and they don't stock one and with the rads in the condition they are in I don't want to even attempt a flush without a filter and run all the sludge through the boiler, I also can't seem to find a flush machine for hire that has magnetic filters.
many thanks
Tap connector ?
thanks shaun
If i'm following you and there is every chance i'm not because i'm a real blonde that would drop the valve down which may cause issues as it's in a cupboard and the filling hose would then be half in half out
Ideally i simply want to re-orientate the return pipe to vertical as opposed to straight back which should give me just enough room to create a loop for a filter to attach to, the only other way I can think of doing it is to have the boiler taken off and pipe reworked and I don't do that as i'm fine with liquid leaking but not ok with boilers booming.
Again i'm probably missunderstanding your idea so I have attached a photo for the current implimentation
Can you draw what you mean as it goes vertical now ?
Thanks for helping with this Shaun, if you see from the image the return valve with the black lever currently attaches to the combi and then the return pipe goes straight back and via an elbow or bend goes behind the boiler and up towards the ceiling.
Ideally what i'm looking for is a replacement valve if one exists that will have the return pipe go down vertically (red) that will then exit the boiler cupboard where I will create a loop and attach a filter which will then pipe (green) back into the cupboard and rejoin the existing pipe that goes to the rads
Tap connector and get a filter with a set of valves etc
Condense pipe will have to be moved tho
Could use existing valve and elbow down, then right and run pipe up the side of boiler.
That's my new plan Timmy, I managed to get up the ceiling yesterday, not easy with a bad leg and steps locked in the garage with no keys (my next project)
I measured all the drops that i would need to go around and I should manage to keep the condensate pipe in place although i'm not sure why it's configured like that and I should be able to avoid the PRV pipe
The only annoying bit I think will be is the return pipe between the ceiling and the top of the boiler cupboard as it has a large coupler possibly pressfit looking at the ribbing taking up most of the clearence so it might be tight in cutting out that section to fit another elbow it's painted white and realy caked on there so i'll know bettter once i have stripped it back to copper.
Reply to alternate straight through CH return valve for combi in the Central Heating Forum area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
