Discuss alpha Intec2 E43 problem in the Central Heating Forum area at PlumbersForums.net
Hi Called out to a Alpha Intec 2 with e43 code, reset boiler it fine for a few days then comes back .It had a new gas valve fitted a year ago by Alpha out of warranty now Can anyone help with this
thanks BigBobby
Reply to alpha Intec2 E43 problem in the Central Heating Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
