Discuss Alpha CB28X Power Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gibberoo
Been working on my boiler after it failed to fire up tonight. The indicator lights A and B on the display panel are flashing at the same which the manual indicates is a fan or flue fault I checked the flue and it is clear I also checked the fan by hooking up a temp supply to it and it operates correctly. I then checked the PCB connections, when hot water or heating is called for there is no volts being sent from the PCB to the fan unit. Just looking for advice to see if I need to replace the full PCB? Or is there anything else I could try?
any info would be much appreciated
Cheers
Industrial Electrician
Sorry mate, I think you are fiddling with GSR only matters.
Reply to Alpha CB28X Power Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
I noticed a few weeks ago that my hot water and heating were not working so I went to check the boiler expecting to see an error code, but on...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
1K
Hello My trusty Vaillant 242 EH is having some issues. It has developed an issue when firing up the burner. The fault is seen with the hot water...
