Discuss Alpha cb24x not firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kerr Gas 1
went to a breakdown today, boiler has 240v and a flashing orange B every 2s, Hot water demand nothing no power to pump or fan, no ignition and the same with a heating call from the mechanical clock, suspected the clock may be faulty so I bridged the switch wire but still nothing, so flashing B orange light every 2s, looking at some sort of board fault, anyone have any thoughts
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Alpha cb24x not firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
1K
Hi! I'm wondering if anyone can help me get my radiators on :) My Salus ST620WBC ran out of battery after ticking over nicely for years. Got it...
2K
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Hi, I have an oil-fired Aga with a BM oil control valve and a Flexitemp thermostatic control (see the image in this thread for an example). When...
8K
Andrew N Yorkshire
A
Hi, i was wondering if somebody could give me some advice..... I was called out to a boiler breakdown the other day. Worcester 15Ri. When i...
1K
