Discuss aldi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Mother in law bought me a makita one a few years ago for crimbo , got to be one of my favourite tools
I've got the Lidl one too. Absolutely ferocious tool. You've got to grip that ******* tight or I fear it'll decapitate somebody or level the house.
Got a hitachi one, great for cutting up galv tanks in roof spaces no nasty sparks
I've got a B&Q one. Total brute of a tool. Hardly use it, but when I do it gets the job done.
Got a makita one with my tool set, made a right mess of my pumpkin this year! :(
When I was subbin to bg, every fitter was told on technical update not to carve up galv tanks with grinder as toxic fumes were released- don't know to what severity but they did always kind of go excessive over everything
Got a Milwaukee m18 hacksall. It's never in van always on the job. Cuts 4" steel right trough to floor boards and it's invaluable when stripping a job. Plus removes immersion in seconds
Ditto. Used all the time
we use the makita/Bosch 10.8v and they are the best tools going saves time on ripping out old copper pipe work, we use it for cutting waste pipe and soil pipe as well as cutting flues to length.
i know exactly what you mean. i cut up an old steel bath in about two minutes. it was like a hot knife through butter it went through so quick.
Blades die quickly but only first 30mm!! Immersion only when scrapping cyl. Broken 3 or 4 of them and had them replaced . ( we have more than one saw being abused by more than one man. )
thought to my self when i read "great for immersions" post , how the hell do you change a immersion with one of them!! haha
i alway use to take them out when i was an apprentice, just till i was confidence enough with changing immersions! it was fantastic practice, good way of learning! felt confidence doing it on a scrap cylinder incase i ripped it! if i was to teach a you lad now i would make him take them out with the cylinder still in place ! good learning!!! but now i dont bother!
I changed a cylinder a few years back, and intended to use the old immersion in the new one, as it was working fine and the 27" ones aren't cheap. I couldn't get the swine out though! LOL.
I struggled for about 15 mins, and thought, sod this. Only time an immersion has ever bettered me. Though I have had to drill and cut them before to remove them on Gledhill Pulsacoils which have waffer thin copper walls which will twist easily.
Good idea to practise on a duff one.
I got the older version from Aldi in 2006, still going strong, only bought it too cut down some Laurels! Good tool for cutting tops off of copper cylinders!
So you guys all remove the immersions. I just chuck mine in as they are. The bloke always knocks off a Kg or so for scale which I sometimes argue.
I've heard of blokes knocking off all the insulation too which sounds too labour intensive to me. Someone once told me you can stick a hoover on it, block off the cold feed and the insulation will just crumble as it implodes. Might try that just for a laugh.
Probably mate, but it's all a bonus so I'm probably lying if I say I'll change my ways.
Reply to aldi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ordered a rip off makita drill a while back and used it for the first time today, its solid and performs better than my apprentices ryobi so if...
3K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
I'm coming on this forum and moderating all posts for a good few weeks, and running searches on old posts. I'm noticing things, and some are being...
2K
Okay, so this is part of a wider efforts to balance the books for the forums. We're trialing it out. But it comes with some good benefits as well...
2K
Ah, the joys of older home ownership (1974). We thought our major plumbing issues were dealt with when we got rid of our orangeburg sewer line and...
2K
