Discuss Alcove Oversize Shower BiFold Door in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
J
John Bourke
Hello,
I have an alcove shower with a wall to wall measurement of 952mm.
I need a bifold door and am looking at something contemporary, 8mm glass with black trim- Issue is that the lower spec limit of the door is 960mm. It seems to be the same with all (Yes I can get a 1000 bifold door in chrome with 6mm glass and large trim that has a lower spec of 950 but its just not what I'm after).
Anyone have any experience of making a bifold door fit? I'm thinking there has to be some additional give in the seals that may absorb the 8mm (4mm each side) - Or maybe the side trim can be modified slightly.
I’ve just installed a replacement bi-fold door and side screen, the minimum dimension is just that, however, the door frame sits within a channel trim which enables, in my case 40mm of adjustment.
Check the manufacture’s literature for tolerance.
Depending on the design of the door and profile- it may be possible to lose a bit of width by cutting down either door frame or profile ( whichever one goes inside, so the cut edge is not seem).
8mm is quit a lot though.
Dare I asked how this cock up occurred, normally a bathroom fitter such as myself thinks the whole job through and this sort of thing does not happen.
Reply to Alcove Oversize Shower BiFold Door in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
