Discuss Air in water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
moreks
I run my own water supply, consisting of a bore and submersible pump, tank, and pressure pump.
The tank gravity feeds the pressure pump.
I recently (3 months) replaced my pressure pump.
A couple of weeks ago I noticed a small amount of air being discharged when I open a tap. This is continuing, and occurs in all taps.
This is not a major problem, more an interesting one.
The only answer I have come up with is an extremely low tank level.
I await your replies
Bill (moreks)
Hi. With the negative pressure created on the suction side of the pump, air can be sucked in if there is a dodgy joint or corrosion.
I understand that, but wouldn't taht then leak, with the flooded pump suction.
HI. (I understand that, but wouldn't taht then leak, with the flooded pump suction.) Under most conditions yes. But It may be the standing pressure in this section is a lot less than the negative head developed by the pump.
Reply to Air in water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version...
