Discuss Air accumulating in system. No pressure loss..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm hoping someone can help...
I have a system boiler (Worcester Bosch 18i - Unvented) in my garage. I am having to bleed top towel rad in house and magnaclean next to boiler daily. Air is getting into the system. I have no loss in pressure. I have removed the lower level rads in house and flushed (some sludge but not too much) I have also run system with X400, flushed and refilled. The air accumulates with hot water and/ or central heating running...
Some parts of the system are under negative pressure this is allowing air to be drawn in without showing signs of leakage. Not so common with a system boiler because the the pump & expansion vessel are normally installed correctly in relation to each other. Check any Auto Air Vents & tighten down there caps just to ensure it is not entering via them. (you may need a Gas Safe Engineer to check the boiler over)
What is the system piped up in, plastic or copper?
Reply to Air accumulating in system. No pressure loss..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
