Discuss Advice needed on shower trap waste!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sparkystu
Im currently fitting new bathroom suit and im a little concernd about the shower waste.
Im installing a walk round shower cubicle. Its basically a 900 quadrant with an extra bit added you walk round to go in. It only has a 50mm waste hole and im fitting a 8" shower head from the cieling. My question is will the 50mm waste hole cope with the amout of water from the shower head. I bought a mccalpine standard waste but im thinking it may need something a little better? Is the such a thing as a fast flow version in 50mm or are they all just a gimmic?? Ideally it would have been better with a 90mm hole, cant undestand why such a big tray only came 50mm.
Any advice welcome!
Stu
MacAlpine top access shower traps take away around 26 litres/minute (over 5 1/2" gallons per min) Regardless of the size of shower head, you would need some serious "power shower" to out run that.
Reply to Advice needed on shower trap waste!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
