Discuss Advice for low pressure when multiple taps are used? in the USA area at PlumbersForums.net
Hi guys,
I am looking for options on how to solve the issue of water pressure dropping when more than one tap is open.
Ideally want some sort of buffer so that if the shower is in use it doesn't suddenly slow to a trickle when someone flushes a toilet! Currently just have a combi boiler but open to all options!
What’s your incoming flow and water pressure figures?
Hi thanks for your reply. It’s take a while to work out.
Severn Trent have said the incoming pressure is 1.9 to 3.8 bar. Avg 2.8 bar.
I’ve done a crude measurement of flow. I’m getting around 10 litres/min in the kitchen.
Would a unvented system be innappropriate?
Is that comparable to what you have at your property?
It’s on the low side for an unvented
I’ve had a plumber out who didn’t specialise in this area and suggested I talk to Severn Trent. They gave the pressure reading but I think they must have just done it remotely.
I’m not quite sure which sort of plumber to call out to get an answer. My usual guy who fitted the boiler and services it doesn’t have a huge amount of advice except for fitting an invented boiler. However, from what I can tell that requires quite a decent incoming flow which I don’t think we have.
I wasn’t sure whether pumps/new pipes/ cleaning out the old pipes are an option. Or if there’s a specific type of plumber who could give me an answer.
Thanks for the advice Shaun.
If you can get him to test the pressure and flow we can go from there
St figures are a guide eg pressure in there pipes
If your pressure is a stable 2.8 bar with a tap running and your only issue is flow an accumulator is perfect for you
But if you only have 1.5 bar it’s not
Thank. Will get back to you.
Reply to Advice for low pressure when multiple taps are used? in the USA area at PlumbersForums.net
N
Hi, i'm looking for some advice on improving the performance of my electric shower as it frequently fluctuates in temperature and flow. The 8.5kw...
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by...
Two connected houses in our 70s condo development, everyone served by one water meter at the road. 833 has 40 lbs of pressure while attached...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
We need an urgent advice, we have a gravity water system and we are in a middle of loft conversion. We are adding an en-suit in loft and prefer to...
