Discuss Adding another radiator in the USA area at PlumbersForums.net
Hi can anyone give me advice please . I have a baxi 128 combi and have 5 1m x800 k2 rads off it so is more than capable to add another . I only have 1 in the lounge and needs another. I have a 2mx800 k2 that I can fit . But my problem is the main pipes in the bungalow attic is 22mm then all radd are t off at 10mm . There is no way I can get in the attic due to very low pitch roof so it looks like the only way is to t off the existing rad in the living room and rute the pies round to the other wall so probly 10m 2 pipes. Would it work is the biggy. If not then I cannot fit another rad
Reply to Adding another radiator in the USA area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
