Discuss 90 ° Isolating Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve
Thanks and Regards. Hugh
I don’t think such a thing exists.
Why don’t you just reduce the 22 down to 15 as it goes into the valve?
15mm angled isolating valves are available any plumbers merchant, toolstation etc , as I expect you’ve found out.
Thanks Ben-gee. Wasn't sure it existed myself but it would have been a good solution
given the way the piping was done and the restricted space I have to work in. I'll get it sorted with currently available components
Regards. Hugh
Reply to 90 ° Isolating Valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
