Discuss 66.7 geberit crimped fitting help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
I have crimped a 66.7 geberit copper elbow and the fitting must of moved slightly before I pressed to crimp it is about 10mm off the insert gauge, I am fully aware that this will void the guarantee on this fitting but how likely is it to leak???
You will be fine wouldn't want to go more than 10mm tho
Thanks for quick reply will be putting an air test on soon if it passes that what's the likely hood it would fail under water?
Thanks for quick reply will be putting an air test on soon if it passes that what's the likely hood it would fail under water?​
Please register with us and start a new thread to receive additional answers to your question.
Reply to 66.7 geberit crimped fitting help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
