Discuss 22mm to 28mm boiler in the USA area at PlumbersForums.net
hi all Iam installing a new combi oil boiler the old boiler (system boiler) had 28mm feed and flow connections new combi has 22mm Iam ok to connect the 22mm straight into the 28mm pipes
Yep doesn’t it come with female threads eg for a male iron ?
For the same flow rate through 28mm the velocity will be less but that doesn't really cause problems on small domestic systems.
The system will still work fine.
Yea only issue if your 50kw plus heating load
Reply to 22mm to 28mm boiler in the USA area at PlumbersForums.net
I'm moving over to a sealed system on my EcoTec 38kw boiler. The old flow and return were in 28mm which was there long before the Vailant was...
Hi All, I am in the process of renovating a property and have the floorboards up installing cabling etc, however it is the plumbing that I have...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a...
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor...
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the...
