Discuss 22mm or 15mm to baths on uvented system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
For a house supplied by an unvented hot water cylinder is 15mm or 22mm usualy taken to the bath taps. I know on a combi its only 15mm require as the cold supplying the combi is only 15mm.
I take 15mm to bath taps, split from a balanced 22 mm feed from the cylinder cupboard
As everyone says, 15mm as it leaves less of a dead leg to exhaust before the hot runs through
I would want the shower supplies as close to cylinder as possible. Not that it would really matter.
So would people feed a full bathroom room shower, toliet, basin, bath off 15mm?
you could run 22mm and branch off in 15mm, but then you could ask why somebodys having a poo while im in the shower.
Reply to 22mm or 15mm to baths on uvented system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am repiping my whole house and changing from combi boiler to a 30kW system boiler & 250Ltr or 300Ltr unvented indirect hw tank. Can somebody...
I recently had an eco tec plus 836 combi installed as part of an oil to gas conversion. One thing I can’t work out is why the bathroom sink hot...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hi I have a 22mm hot and cold water supply to new bath. The pipes finish with compression valves. I need a 500 mm tap connector hose to connect...
A
The bath taps have 22mm inlets currently the cold water mains 15mm is fixed to the tap by a copper adapter 15mm to 22mm. The hot water is 22mm...
1K
