Discuss 15mm pipe at bath from central heating boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, First post here...
My son is currently doing up his house and just had new CH Boiler/rads fitted but the hot pipe outlet from the boiler is a 15mm pipe and goes to the bath, kitchen sink and bathroom wasbasin, now I would have thought it should be 22mm out to the bath and reduced down to 15mm for the sink & wasbasin.
Original pipework is 15mm for some reason? and this is what it has been connected to.
Intending to replum bathroom and fit new bathroom suite (easy access as it's above kitchen and currently no kitchen ceiling due to previous burst pipe.
should we put in 22mm pipework from hot water outlet of boiler?
thanks
thanks
I would
Do you know the model of boiler and kw size ?
Standard size pipe from a combi boiler is 15mm so if you have a combi its pointless running 22mm pipe
Exactly if it’s a combi they can only produce xx amount of hot water so I’d leave it
Thanks for the reply guys..
If it's any help it's a Worcester 36CDI Compact REP Condensing Combi boiler
cheers
OK..Thanks again for all your input and advice 15mm it will stay we're Sparkies so it's good to get the right advice
.cheers
.cheers
You kept that quiet about being Sparkies ! If we had known that we wouldent have told you anything !! :p:p:p:p:p:p
Reply to 15mm pipe at bath from central heating boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
